Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Lenovo G50-70 puede identificarse mediante la información del modelo impresa en la parte inferior (nombre del modelo 20351), o en una etiqueta junto al trackpad. Este portátil tiene una pantalla de 15.6 pulgadas con audio Dolby. La fabricación comenzó en 2014.
My PC doesnt start anymore after disassembly
hi to all,
i tried to fix the display of a laptop lenovo g50-70 (it blinked when it was moved), so i disassembled it, and tried cleaning the wires that connected the display to the mobo, now the PC doesn't start, the fan doesnt start, i dont hear the hdd spinning, but the power and charging leds are on. someone can help me on what it could be the problem?
Update (06/05/2021)
Imagen
i have cleaned the connector with this, before cleaning the display was going on and off, yes the changing light turn on when i plug the power in
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
i have resolved by removing the bios battery, now it’s booting! ty anyways
- de
@lcxbnr thats good to know that a CMOS battery can cause that type of issue.
- de
Agregar un comentario
2 Respuestas
What did you clean the connector / wires with? When it blinked, did the screen go off and then come back on? I know that RAM issue can cause some strange things to happen such as display and no boot.
Does the charge light come on when you plug in the power adaptor?
Update (06/05/2021)
If your pc has two sticks of ram take them out and boot the laptop up and see if it posts. If so then test each stick of ram by placing one in at a time.
Fue útil esta respuesta?
Puntuación 0
Hello.
I had this problem. I mount and dismount the PC several times. All was according to manual and youtube videos. When I plugged the power adapter the fan moved a little, then stopped, light in the power indicator switched on, but pressing the switch on button didn't work. I read that these computers had issues with the RAM memories. I removed one of the two I have. I tried again, it worked. I switched the position of the two memories, it worked again.
Just in case this is helpful for someone, I wanted to post.
Puntuación 0
Añadir tu respuesta
Luca B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 776
