Saltar al contenido principal
Un ordenador personal que reside en una ubicación con sus componentes principales dentro de una caja separada de los periféricos de terceros necesarios para la operación, como un ratón, teclado y monitor.
PC randomly reboot during gaming (temps are ok)
My PC randomly reboots while gaming.
Sometimes it happens in menu without launch a game, sometimes 5 min after start, sometimes 3-6 hours or none - no pattern there.
It happens in 3 of 4 games i playing currently:
  • Euro Truck Simulator 2 (4-5 hours)
  • American Truck Simulator (0-5 min)
  • Natural Selection 2 (1-3 hours)
PC Rig:
  • CPU AMD Ryzen 3 3100
  • GPU NVIDIA GeForce GTX 1050 Ti 4GB Low Profile MSI
  • PSU Corsair SF450 450W (changed from Chieftec CSN-650C 650W - not helped)
  • MotherBoard MSI B550M PRO-VDH WiFi (came back from guarantee - not found any issue with that part, it’s 100% ok)
  • RAM GoodRam IRDM X DDR 4 1x16GB 3200MHz CL16 (changed from HyperX - not helped)
  • SSD AData SwordFish 1TB
  • 4 fans 80x80
Max temps (during games):
  • MotherBoard: 48C
  • CPU: 59C
  • GPU(hot spot): 78C
  • SSD: 40C
There is a log from last reboot:
The system was rebooted without a clean shutdown first. Possible causes of the error: The system has stopped responding or has crashed, or there has been an unexpected loss of power.
Nazwa dziennika:System
Źródło: Microsoft-Windows-Kernel-Power
Data: 31.05.2021 15:22:00
Identyfikator zdarzenia:41
Kategoria zadania:(63)
Poziom: Krytyczne
Słowa kluczowe:(70368744177664),(2)
Użytkownik: SYSTEM
Komputer: DESKTOP-3SAEVNN
Opis:
System został uruchomiony ponownie bez uprzedniego czystego zamknięcia. Możliwe przyczyny błędu: system przestał odpowiadać lub uległ awarii albo nastąpiła nieoczekiwana utrata zasilania.
XML:
<Event xmlns="http://schemas.microsoft.com/win/2004/08...>
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2021-05-31T13:22:00.5246757Z" />
<EventRecordID>24024</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-3SAEVNN</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
I have no idea how to fix it now. Please help
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Your GPU looks to be the problem try warranty replacing it.
Fue útil esta respuesta?
Puntuación 0
It could be bad wall outlet, Power Supply Unit (PSU), Motherboard, or RAM. Check for hardware driver updates. The best bet will be the wall outlet or PSU. If you have another PSU try it and if the problem no longer occurs then it is the PSU.
Puntuación 0
Añadir tu respuesta
Yardi Official estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 200
