Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La calculadora portátil TI-Nspire CX cuenta con una pantalla retroiluminada a todo color, un diseño fino y elegante, e incluye la batería recargable TI-Nspire.
White screen when I tried to run pokemon emerald on a Ti Nspire CX II
When I tried to run pokemon emerald on a Ti Nspire CX II, it just gives me a white screen and I don’t know the reason behind it. I reset my calculator multiple times. I have endless installed. It worked one thing and after that, it never worked and whenever I tried to run it, it just gives me a white screen. Can someone show me how to fix it or teach me? That would be appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
To be clear, your calculator is functioning normally as a calculator, it just won't run Pokémon?
If so, try moving some files from your RAM to your Archive. Unfortunately I don't know much about the Nspire calculators, so you'll be better off posting a question like this over on TI-Planet where they specialize in all things Nspire. Although the site is in French, the members will be happy to help you in English if you need. Here's the best place to post your question: https://tiplanet.org/forum/viewforum.php...
If you can't get the calculator working normally, try following this guide: https://tiplanet.org/forum/viewtopic.php...
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I was able to run pokemon emerald for a bit. After a while, when I tried to run pokemon emerald it just gave me a white screen. I am also able to run pokemon silver.
- de
Añadir tu respuesta
DAVID ZHENG estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 26
Todo El Tiempo: 700
