Radiator fan turns on late
My radiator fan kicks on at 220f, works for less than a minute and off it goes. ive changed the thermostat, the sensor on the thermostat and the sensor on the radiator but still have the issue, any suggestions?
Es esta una buena pregunta?
Puntuación
0
When the motor kicks off is voltage still being sent to the motor?
- de brandon k
Im not sure, it turns on for less than a minute and off it goes..
- de William Rivera
check with a meter and see. If you are getting voltage then the fan motor is bad. If not, you'll have to trace the circuit back from there to find the issue.
- de brandon k
