Saltar al contenido principal
Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
Preguntas 20 Ver todo
Ribbon cable disconnected from keyboard
When replacing my ssd I accidentally pulled the keyboard and the ribbon cable that connects with the motherboard disconnected (on the keyboard side). My question is - is there an easy way to connect it back? I probably will need to unscrew the metal plate covering the connection… but for now I dont have T3 screwdriver.
Update (05/28/2021)
Well I will get my hands on a right screwdriver on monday. I searched a bit and this seems to be the connector under the sheild.
The left part and right part seems to be taken already by two other cables, thats why I am not sure yet how to connect it... will have to try it out later when i get the screwdriver, i guess.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi as i see there is no connector visible so i guess its hidden under the shield so maybe you can take off the metal shield and see what’s going on.
Maybe you can look here at 0:50 to get an idea of where the wire is connected. (indeed its under the shield)
https://www.youtube.com/watch?v=OpXizbze...
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Yes, well i will get my screwdriver on monday and see then. Also I searched a bit online and found a connector that seems to connect with the cable. Its in my update.
- de
Añadir tu respuesta
Aaron Sitek estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 31
Todo El Tiempo: 1,382
