Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
2 comentarios:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
- de Anonymous
- de ruth
