Saltar al contenido principal
Tableta de 0,622 kg (1,4 lb) con pantalla de 10,8 pulgadas y soporte de 3 posiciones lanzada por Microsoft el 5 de mayo de 2015. Número de modelo: 1645.
My screen is so faint I can only see it in a darkened room.
Screen not broken and everything still works but screen so dark I can only read in darkened room. Have updated driver etc but no luck
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
First thing that comes to mind is a backlight failure. If this isn’t the case I would think it could be a display connector issue. Chances are that if it isn’t an OLED or in a OLED family it is a backlight failure.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Thank you for your answer. Do I have to replace the whole screen or can I just replace the backlight? I'm not sure what to do as it is quite old and the screens seem expensive.
- de
I don't know where you would find parts you can trust for this machine. I would just replace the screen completely. IFixIt has a screen for $180. I don't really know what would be the best way to resolve this, this is as I can't find any information on the screen other than microsofts special names for their parts.
- de
I would also add that it might be the display connector. Have you opened the machine up and checked any connections?
- de
Añadir tu respuesta
PREmi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 109
