Saltar al contenido principal
Why can’t my Dell precision 5510 keep a charge?
My laptop’s battery kept getting worse and worse. Eventually it couldn’t keep a charge. Laptop would still run on AC power but it would randomly power off abruptly. I changed the battery. Powered up and it seemed ok. It said that it was charging. At one point it reached 100%. I kept it plugged in in order to calibrate the new battery. Then the original issues returned. I’ve also gotten messages that it doesn’t recognize my charger even though it’s the official one that came with my laptop. I updated everything and it happened again. Now it will not start for more than a second. There’s a blinking orange light near the trackpad but doesn’t blink a consistent amount of times. Any info is welcome. Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
a clue might be that it doesn’t recognize charger. There are many posts elsewhere about this. Apparently, the charger has 3 connections +, -, and sense. If the LT does not see the sense lead, it won’t charge. This can be cause by dirt in the adapter or computer sockets, a bad adapter cable, bad internal cable or bad circuit on the MB in order of fixing ease and cost.
Start with blowing out the sockets and wiggling cables. A bad cable will probably require a new adapter, Internal cable assy are available, as are MB, but that can be expensive.
Fue útil esta respuesta?
Puntuación 0
I had a similar problem. I doubt it is your issue because my Dell laptop was new. All I can tell you is be sure the a/c charger is completely plugged in to your laptop. I had been pushing my charger plug in to my laptop but I was not pushing it completely. My laptop would not charge while I was using it and it did not recognize the charger. If I left it overnight it did charge. Once I realized I needed to push the charger plug in fully everything is working perfectly and no more message about not recognizing the charger. Hope this helps or you are able to find your issue. Paul S. Heimers
Puntuación 0
Añadir tu respuesta
Mateo Gaitan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 545
