What should I try next? Moto X4 will not power on - does not fastboot.
I found my phone powered down after a nap. I have been unable to power it back on since.
Things I’ve tried:
- Checking the charger works with another phone (my partner also has an X4).
- Cleaning the charging port of all debris.
- Charging the phone for 24 hours.
- Holding the power button down for 40 seconds.
- Holding the (-) volume button and power button down for 2 minutes.
- I replaced the battery using iFixit moto x4 battery kit. One of the connector locks has broken off so I used a dab of silicone to keep the connector in place.
- Connecting the phone to my PC seems to be the only sign of life. The audible connect is heard but the device doesn’t show a connection. However, it does show in the device manager under ports. Looking closely there are three events, one of which is a warning. I’ve copied and pasted the key information below.
Log Name: Microsoft-Windows-Kernel-PnP/Configuration
Source: Microsoft-Windows-Kernel-PnP
Level: Warning
Description:
Device USB\VID_05C6&PID_9008\5&1d9b8640&0&6 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_046D&PID_C52F\5&1d9b8640&0&6
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Location Path: PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(6)
Migration Rank: 0xF000FFFFFFFF0023
Present: false
Status: 0xC0000719
I am beginning to suspect this phone is now bricked. Seems odd that this would happen during normal use. I suspected the battery was the problem initially because I’ve had this phone a few years and I have definitely noticed the battery life beginning to wain. Thanks in advance for any assistance you are able to provide.
Es esta una buena pregunta?
