Saltar al contenido principal
Adaptador de corriente alterna magnético de segunda generación para productos MacBook, lanzado por primera vez en 2012. No es compatible con sistemas de generaciones anteriores Disponible en versiones de 45W, 60W y 85W.
Preguntas 23 Ver todo
2-Prong Pin loose, causing intermittent connections
One of the prongs for my charger is loose and it’s causing the charging connection the cut in and out. The cable is in great condition and my port has nothing stuck in it, so I know it’s likely not those.
I have attached a video showing the loose prong. It requires me to plug in A/C cable very carefully, as fully inserting it disconnects the power. The issue occurs whether I use the duckhead adapter, Apple extension cord, or any 2-prong power cord
is this easily fixable? I would hate to just throw this away
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Sadly, there is a point when its just smarter to replace the charger, this is one of the cases. ;-{
You could try getting some glue where the pin fits in. I’ve had mixed success.
Make sure you get a REAL Apple unit as many of the Amazon or eBay units are knockoffs which can damage your system!
The real MacCoy! Apple.Com - MagSafe Power Adapters
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
David Chun estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 671
