Saltar al contenido principal
Un ordenador personal que reside en una ubicación con sus componentes principales dentro de una caja separada de los periféricos de terceros necesarios para la operación, como un ratón, teclado y monitor.
Preguntas 317 Ver todo
Desktop monitors, tried 3, wont turn on after computer froze.
Weird sound then short electrical hum. Screen froze. Manual computer restart. Can hear it but monitor is black. Monitor check on another computer. Monitor is fine. Checked cables. Blew out dust. Tried different graphics card and nothing. Monitors - tried 3- still wont come on. Which hardware part could have blown?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios:
Hi Helen,
Which model especially the actual mainboard model name and number . Will most likely be printed right on the circuit board.
Also CPU if you know which one.
With that information we may be able to help you.
There are many possible solutions.
- de
2 things come immediately to mind. Does your PC go through the entire boot process? By that, I mean, your fans turn, lights flash and the pc runs the BIOS that checks all the hardware(pc, memory, floppy, HD,CD/DVD and video. If your video is misconfigured in your BIOS, it could cause this problem.
Can you get into your BIOS to check this problem?
- de
Agregar un comentario
1 Respuesta
Change psu, reset bios see if it works, check for visual damage on MB, use new 3v coin battery. Try leting system sit for a while with no 3v bat & -/+ shorted with a cable. See if with no ram or CPU the system beeps. If all fails could be a short/chip or vrm from MB.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Helen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 43
