Saltar al contenido principal
Tablet PC de alto rendimiento de segunda generación lanzada por Apple en junio de 2017. Modelo A1670.
Preguntas 36 Ver todo
What part do I need to change out the charging port for my IPad Pro 2?
What part and tools will I need to change out the charging port for my IPad Pr 12.9 2nd generation? This will be my first attempt to DIY a repair. I am hoping to find a how to video as well.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The charge port is soldered onto the board and is not a repair you should DIY as you can easily mess the board up and cause more damage and requires thousands of dollars in tooling. Send it to a board repair specialist like iPad Rehab, STS Telecom, Rossmann Repair, or VCC Board Repairs. All of them has youtube channels you can check out. I personally use VCC for repairs I can’t handle in my own repair shop so they certainly know what they’re doing but you can’t go wrong with either of them. But if you don’t mind me asking, why are you replacing the charge port? Do you need to wiggle the cord just right to get it to work?
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Hi, so at the moment i will not change it but i have thought about it because compared to all my other apple products the port seams lose. And when i move the cable sometimes it stops charging. Also when charging the apple pencil it also seams lose and wont charge unless i hold it strait... what do you say? Should I change it? Or is there another fix you know of? Thanks in advance!
- de
@appletopic you can try cleaning the port out. sometimes dirt and debris can find it's way in there. Fine tipped tweezers should do the trick
- de
Añadir tu respuesta
Donna K Zorn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 449
