Saltar al contenido principal
La Dell Inspiron 11 3000 es una computadora portátil fabricada por Dell diseñada para tareas que requieren una potencia de procesamiento mínima.
Preguntas 1 Ver todo
Why dell inspirion can't on
my dell inspirion 11 3000 sometime can on but sometime cannot why this happen
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi @wakjal ,
It may be an intermittent problem with the Power button.
Here’s the owner manual for the laptop.
Go to p.31 to view the necessary pre-requisite steps and then the procedure to remove/replace the Power and Volume buttons board.
Once the board has been disconnected from the motherboard use an Ohmmeter to test if the Power button contacts are making OK everytime that the button is operated and if not then the board will have to be replaced, (supplier example only to show cost of board).
There are other suppliers online that may suit you better. Just search for 450.06Q04.0001 to get results.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Mohamad Faizal Harun estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 126
