Saltar al contenido principal
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
How to install chinese language in n8?
i got a n8 and it cannot show chinese language,how can i install myself?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
how to install chinese language in Nokia N8
- de
check out old turkey's answer.. if you want more help then you should start your own question.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
You can check and see what language are available to you by
Select Menu > Settings and Phone > Language .
Change the device language
Select Phone language.
Change the writing language
Select Writing language.
Activate predictive text input
Select Predictive text.
If you do not have Chinese in the option, then you need to have the language pack containing Chinese installed at your local Nokia Care Point. Problem is that you will lose this language pack everytime you update the firmware. The phone will always revert back to its original language pack.
Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Suettheng estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 4,133
