Saltar al contenido principal
El Dell Inspiron 11-3147 es un dispositivo híbrido de portátil y tableta de 11". La pantalla se puede plegar hacia la parte posterior para permitir el uso del ordenador de mano. Fue fabricado en agosto de 2015 por Dell.
Preguntas 13 Ver todo
Hinge problem: Why does the hinge get stuck
My Dell Inspiron 11-3147 fell on the floor and as a result of the drop, and one of the hinges will not rotalte fully any longer. I cannot close the laptop, neit Iher can I fold it like a tablet. That hinge will only rotate a little in both directions, then it gets stuck. I tried to force it a ittle, but it won't turn/rotate any further. I did not force it too much so that I won't break it. Does it have something inside of it that can cause it to get stuck? Some sort of mechanism?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
  1. Unplug charger.
  2. Remove the screws on bottom cover
  3. Remove battery
  4. Unplug & loosen the hard drive cable. ...
  5. Unplug & loosen the antenna cables.
  6. Remove the bracket screws. ...
  7. Remove the tape. ...
  8. Open the laptop flat. ...
  9. Use fingers to pry apart and separate back cover from screen.
This video should help :
https://www.parts-people.com/blog/2018/0...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Mike Turk estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 28
Todo El Tiempo: 1,352
