Saltar al contenido principal
Guías de reparación y soporte para afeitadoras eléctricas, cuchillas y hojas de afeitar desechables, y maquinillas de afeitar rectas, tanto para hombres como para mujeres.
Preguntas 20 Ver todo
Replacement motor for Panasonic ES-LV95 cleaning station (RC9-15)
So I noticed that my cleaning station no longer cleans the shaver (the water doesn’t seem to be pumped) it only is capable of drying. I opened it up (actually not super difficult, but need to be careful), and eventually I got to the motor of the pump. It appears to be all rusty (no surprise, since the design places it under the water level, and only thing blocking the water are seals).
Anyway, I don’t think Panasonic will provide me with a replacement motor (I still asked and waiting for a response), so I’m wondering if I can find an off the shelf motor that could take it place. I really doubt Panasonic would build a special motor for a cleaning station so it probably also is off the shelf motor, but I know absolutely nothing about DC motors and how to find one matching it.Unfortunately, the motor is wrapped in special plastic case so I can’t see any markings that would help me find that part. I haven’t tried hard enough to remove it from it (because I’m afraid that I might break it). I’m wondering if there’s some kind of catalogue of DC motors with dimensions so I could look and perhaps locate which one I need? I don’t even know where to look for something like that.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
I have the same issue. Curious to know how you go about disassembling the thing. Thanks.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
typically in their eyes ( panasonic) the charging \ cleaning station is so cheap theyre not going to offer replacement motors for this kinda thing.
odds are youll have to dig around the google machine and see if anyone else has done this repair on the side and hope they listed the motor. ill search around and update if i find anything
if no luck there then youll have to get measurements of the motor physically and then some how figure out the motor speed and required voltage \ amperage.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
this further proves they dont care about component level repairs lol
https://panasonic.encompass.com/model/MS...
- de
Oh the off chance you still own this station, these motors seem to be the correct replacement: https://www.amazon.com/dp/B07SR7NBNC?ref.... I coated the shaft with an acrylic conformal coating since my old one has rusted, I then added silicone sealant around the gasket to prevent water ingress into the motor. This all seems to work. Maybe this answer will help somebody else keep something out of the landfill.
Puntuación 1
1 comentario:
Any info on how to access and remove the motor? Thanks.
- de
FC-11285 0907 5V DC (part ID hardly legible despite I cleaned the motor with care).
Unbranded.
Shaft: 2 x 10 mm
Flat body: 30 x 15 x 22 mm
Torque, and speed and direction of rotation: no idea.
Puntuación 0
Añadir tu respuesta
takeda estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 28
Todo El Tiempo: 1,899
