Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Why will my laptop not power on?
I accidentally dropped my laptop and the screen started glitching. I turned it off then right back on and it was fine. I then closed the my laptop and when I went to use it again it would no longer turn on. I’ve plugged it up and nothing. No lights come on whatsoever.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
When you connect the power do you see a light indicating that it is charging. Usually blue or amber? Steps to try
1: Try from different outlet
2: Try from different power connector (If possible)
3: Clean power input with alcohol with qutip and try again
4: If under warranty you may need to send it in. If not under warranty you may need to open laptop inners and check that power connect is connected to motherboard.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
stephyrm1985 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 234
