Saltar al contenido principal
Guías de reparación y solución de problemas para Acer Aspire V5, una serie de portátiles con sistema operativo Windows de Acer.
Preguntas 20 Ver todo
I cannot access my Bios on my Acer Aspire V5
I accidently turned it off on startup and it wont boot to the splash screen now the screen just flashes a slight green and it wont let me go into the Bios to boot from a USB flash drive to install windows 8.1. Any help?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You probably have corrupted the boot files but let’s check out these other things first as you should be able to access the BIOS/UEFI.
Unplug charger from laptop, take battery out and press power button to discharge all power from computer.
Plug in charger and turn on. What happens?
Turn off.
Unplug charger, install battery and turn on. What happens?
Turn off.
Now plug in charger and turn on. What happens?
By looking at the Power and Battery LED’s you will know more about what is happening:
Power Indicator Light
  • Off = System is off.
  • Blue = System is on.
  • Amber flashing = S3 state.
Battery Light
  • Amber flashing = battery low charge.
  • Amber (not flash) = Battery charging.
  • Blue = battery is fully charged.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
TJ0410 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 1,428
