Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Tablet PC de alto rendimiento lanzada por Apple el 11 de noviembre de 2015. Modelo A1584.
Battery won't charge after display replacement
I successfully completed this guide but when I put everything back together and turn it on, I only see the low battery indicator (even when plugged in) I left it plugged in for several hours but I only ever see low battery. Occasionally the screen will light up with the Apple logo and show the keypad. It even registers a couple of key presses but before I can enter the passcode the iPad turns off. What is going on here?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Double check if the battery connector is properly seated. I recently noticed something similar with an iPhone where the connector wasn’t 100%, but just enough for it to power on, but not to be properly detected in order for it charge.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I took it to a repair shop and they confirmed it was in a boot loop. it's such a common problem with my particular model of iPad they refuse to fix them. I've since given up on it.
- de
Añadir tu respuesta
Brandon der Blatter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 178
