Single vertical shadow line on A1534, flex cable or display broken?
Hi all, unfortunately my MacBook 12 (A1534) 2015, few weeks ago starts to having the issue shows in the picture, a single vertical shadow line of about 4-5 cm near the center of the screen. The MB never fallen down and never caught a hit.
The line appears sometime, but once it come it doesn’t go away.
After reading many post in different site or forum, I don’t think the problem is a damage lcd panel but a damage or defective flex cable that connect the motherboard to the display.
Any of you guys have the same issue? Any suggestion or resolution?
Thank in advance
Update (02/12/2021)
Hi @danj, thanks for you illuminating reply!!
Yesterday I didn’t thinking to make a simple but revelatory check like duplicates the laptop screen via hdmi on an external display…. I done it this morning and, yes, only the MacBook display had issue…. so your supposed idea was correct, probably my MacBook has a failing display.
I attach a picture taken with iPhone, to show what I reffer to, but after your reply I saw that the picture that I’ve attached yesterday, opened on another device, didn’t show the shadow line.
Now, the new question is, is possible to change the lcd/retina without changing the entire display assembly?
Es esta una buena pregunta?
