Saltar al contenido principal
Versión renovada del iPhone 3G con velocidades de procesamiento más rápidas. La reparación de este dispositivo es similar a la 3G y requiere destornilladores simples y herramientas de palanca. Modelo A1303 / 16 o 32 GB de capacidad / respaldo de plástico negro o blanco.
Preguntas 1502 Ver todo
Earspeaker/Loudspeaker not working after screen and battery replaced?
Greetings,
I replaced my lcd display and battery recently but now I have no sound coming from the earspeaker and loudspeaker. The proximity sensor works just fine on my phone, but I can't hear anything.
No sound at all from the loudspeaker nor earspeaker. Any suggestions as to what may have caused my phone to be mute? It works if I use my headphones. I cleaned out the headphone port as well, so I dont think this is a problem with the headphone port, making it stuck in headphone mode.
Would replacing the headphone assembly fix my problem, or replacing the whole dock assembly do the trick? Any suggestions would be much appreciated. Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
There is a possibility that you tore the connection between the #4 ribbon and the black dock speaker. It happens from time to time, and it is very hard to notice. Check for tears. As for the ear speaker, perhaps the #3 ribbon was damaged as well in the process. Sometimes these things are bent or twisted just enough that either prox sensor doesnt work, or the ear speaker doesnt work, or even both. So even though one works and the other doesnt, it does not mean it isnt damaged.
DIY for the #3 ribbon
iPhone 3GS Proximity Sensor Ribbon Replacement
Fue útil esta respuesta?
Puntuación 1
It is stuck in headphone mode
insert headphones
open ipod app
play a song for 5 secs
pause the song
restart phone
unplug headphones
This will reset the headphones setting
Fixed alot of issues that we otherwise couldn't.
Puntuación 0
Añadir tu respuesta
lilmark86 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 6,688
