Saltar al contenido principal
La PlayStation Vita es el sucesor de la PSP. Contiene un procesador y gráficos mejorados, e incluye la adición de un segundo stick analógico. Fue lanzado el 15 de febrero de 2012.
Preguntas 160 Ver todo
Got Ps Vita wet, and won't properly work
Hi. So one day I had a sticky substance on my Ps Vita. I resolved to over-wetting (I guess?) a paper tissue and wiping around the screen. I might’ve done something with the screen/over wet the screen and now, the Ps Vita won’t on when wanted (via the power button) and would only work when you use the ps button. If I do get to the flick screen to get to the application/selection screen it will, (most times) introduce the power off and cancel screen, which (no matter what you decide within a few seconds given) it’ll off and you’ll have to turn on the Ps Vita again (with the same problems). If I also make it to the application/selection screen, whichever application/game you choose, it’ll trap you in it, making the only way out is to turn it off again, and also repeat the whole process to get to the same spot again. I tried resetting and doing all of the "Reset and delete everything on the memory card” process a handful of times, yet it didn’t do anything. I have also tried out things that youtube recommends, and other things. If you leave the Ps Vita alone, it’ll suddenly start to proceed to the DFU Mode selection screen (it does happen in the middle of the night as well), it’ll just stay there and then off, then doing the same cycle again.
I really love this Ps Vita and I want to fix it so I can still play on a legacy gaming console from Sony.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @sonylover
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the game console’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your game console and then remove the battery as soon as possible from the device to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible, do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as there may be water and corrosion under there as well. The ends of any flex cables and their connectors need to be cleaned as also
Hopefully after you have done all this the device might possibly work correctly again.
Here is a link to the ifixit PlayStation Vita Repair guides which may be of some help.
If this process seems too daunting, take your console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
do you have any Ps Vita repair stores near you that I may be able to contact, I live in New Zealand. Here, Ps Vita's are not a thing that people fix these days. Im just trying to get a place as soon as possible, even if I have to mail it in.
- de
@sonylover
Not being in NZ I don't know but you could try contacting this repair service.
I have no personal experience with using them but the owner has been writing repair articles (not just related to computers but all forms of electronic devices) for an electronics magazine (Silicon Chip available both in Aust and NZ) for a long while now so maybe worth a try.
The contact link is in the webpage.
Use the repair guides to remove the battery as a minimum even if you don't do anything else
- de
Añadir tu respuesta
Philp estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 402
