Saltar al contenido principal
Modelo núm. A1367 / Capacidad de 8, 16, 32 o 64 GB
iPod Touch 4g without backlight?
hi i have an ipod touch 4g 8gb that i can sync with tunes and everything but the problem is that y can see the apps or folders or pics because the backlight is off and i just can see the lights with an external light o lamp can i fix this with just change the lcd ? or buying and lcd assambly and he dont have a water damage thanks.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Have you checked the brightness in the settings. if checked then try to restart the iPod sometimes happen. if still same then it could be your Lcd. may be or in logic board . first try these after that change you lcd it will 99% solve your problem.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
so i replace the screen and the digitizer and is fully funcional thanks
- de
Añadir tu respuesta
gmaincomputerservice estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,171
