Not starting and Logic board debug
My a1347 Mac Mini has been turned off for a few years and now it will not start. When I press the power button the fan goes on for a second, the light goes on for about a second too and it makes some sort of sound. The sound is not the fan as I also hear it with the fan disconnected and I have some distant memory of that the sound always there on start.
I have checked that the power supply gives 11.8V on all 4 pairs as of this guide so it appears to not be the problem. Complete Dead - How To Check Power Supply Vs Logic Board
So now I am rightly of wrongly looking at the logic board. I have read in a few other forums of failing capacitors near the power supply on Macs. Can someone point out where in the photos these might be? Other ideas of where/what to check and how are also appreciated.
Es esta una buena pregunta?
Did you replace the NVRAM coin battery?
- de Dan
No but I measured it to be under 3V. Is that enough voltage?
- de Alpaca
If the system had been sitting unplugged it will need replacing. I would start there.
- de Dan
I changed the old battery (2.9V measured) to a new one (3.3V measured) but it didn't help. Still the same when starting the Mac Mini. Any other ideas?
- de Alpaca
So can anyone point where the capacitors are on the logic board that are related to the power supply?
- de Alpaca
Mostrar 1 comentario más
