A1224 Kernal panic and bootloop
I obtained a older iMac recently and found it was bootlooping. I have a boot disk, however it will not mount or boot for that matter. I’ve tried every key combo in the book. Any sugjestions
Let me also note that I only hear the chime over and over about 2-3 seconds apart.
I also have no video or logo on the screen.
Es esta una buena pregunta?
Puntuación
0
A system which is in boot loop often points to a POST error condition.
Restart your system and with a USB keyboard plugged in press the D key to enter into diagnostics. Depending on the OS-X release you might not get in at which point you would need the original grey CD/DVD's that came with the system to boot up under the one that has diagnostics on it.
- de Dan
I don't have the cd, but I do have a USB drive with the correct os on it. Will this work. Also could my usb port be bad if it none of the the key combos work.
- de Jordan Hasty
Sadly these early models will only boot up under FireWire drives, not USB
- de Dan
Will it work with the built in cd drive or no?
- de Jordan Hasty
@yeetkid - if the CD is properly set up, yes
- de Dan
Mostrar 2 comentarios más
