Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
ali92 @ali92
Rep: 1
Publicado: 2 de ene. de 2021
Why is my 2012 Mac Air stuck after one hour
Es esta una buena pregunta?
3 comentarios:
How so?? You'll need to give us a bit more here. Does it not startup? What does the MagSafe charger LED telling you? Is it Amber or Green. Did you have a spill or bang/drop your system? Given its age have you had someone replace the battery?
2 de ene. de 2021 - de Dan
i dint change the battery , do u the battery issue ? thxc buddy ,
3 de ene. de 2021 - de ali92
Can you answer the other points of what I asked
>> Does it not startup? Do you hear the fan spin up?
>> What does the MagSafe charger LED telling you? Is it Amber or Green?
Its a matter of following a diagnostic process. A then B then C and onward...
If you want to just jump to Z thats fine but it won't necessarily get you to the to the best answer!
3 de ene. de 2021 - de Dan
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 15
- de Dan
- de ali92
- de Dan
