Saltar al contenido principal
Una máquina de café expreso para el hogar fácil de usar creada por Saeco y rebautizada para Starbucks. Esta máquina es excelente para los bebedores de espresso y tiene una excelente construcción y vida útil.
Preguntas 140 Ver todo
Pregunta Cerrada
The screen say "Empty Grinder" - how do I fix it?
The machine seems ready to go- it says "Select shot size" as it normally does- but when I select a size, it starts like it should but makes an odd noise like it can't grind anything. Then it displays the message "Grinder Empty." I've checked both the water and beans and they are full. I've also turned the machine on and off. Help please!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi,
sometimes there are small stones in the coffe beans. When a stone gets stuck in the grinder it might happen, that the machine thinks the grinder is empty. The grinder should start grinding even if there are no beans.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Thanks for the help! So should i just try to clean out the beans??
- de
Unplug the machine, clean out the beans and take a closer look at the grinder. Read the manual what to do if there is a stone stuck in the grinder.
My Jura S70 had a special wrench to turn the grinder backwards in order to get the stone out of the grinder.
- de
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 598
