Saltar al contenido principal
Información de reparación y desmontaje para el iPad Pro de cuarta generación de 12.9 ". Anunciado y lanzado en marzo de 2020. Modelo A2229.
Preguntas 20 Ver todo
Usb c to 3.5mm with microphone
What is the solution to using an Astro A10 gaming headset with attached microphone on the newer ipad with no headphone jack? I've seen dongle usb c to 3.5mm adaptors for sale but they only support audio not microphone input/output also.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
The iPad Pro 4th gen offers a full USB-C interface which does offer bi-directional input/output.
But you need to re-think your expectations! You’ll need a bit more gear to get this to work via a wired connection to get the input to also work through the headset.
Most people just use a good Bluetooth headset to get around this limitation. But, are you sure you want to use this iPad for gaming?? It’s not really designed to support long duration game play.
Fue útil esta respuesta?
Puntuación 1
I can confirm that the Apple original USB C to (3.5mm) Headphone adaptor DOES work with an external microphone. I bought a Belkin adapter that does not work. The Apple adapter apparently includes TRRS compatibility. The Belkin I bought does not.
Puntuación 1
Añadir tu respuesta
Litman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 988
