Saltar al contenido principal
El Kindle Oasis de Amazon de tercera generación, que se lanzó el 24 de julio de 2019, cuenta con una pantalla de tinta electrónica de 7 pulgadas y 300 ppp, luz cálida ajustable, diseño para una sola mano, impermeabilización, exterior de aluminio, compatibilidad con Bluetooth y micro USB para cargar. Este lector electrónico viene en dos colores: Graphite o Champagne Gold.
How to open Oasis 3 to change battery?
I would like to know how to open the device to change the battery. At the moment it is not necessary but because the battery runtime is about the same on my 6 month old Oasis 3 as on my 6 year old (heavily used) Paperwhite i bet that i will have to change the battery after ~3 years.
Update (10/12/22)
Don´t get me wrong. I love my Oasis. Size, buttons to flip pages, automatic orientation rotation and case shape (which makes it extremely comfortable to hold). But the battery size is a joke. One day of heavy reading and the battery is down to 10%. If i could easily open the case i would try to fit a bigger battery.
I did some modding with my old Paperwhite years ago. And also changed the Battery after a few years. Even added a Qi receiver to charge it wireless.
Probably will try to open my Oasis in the future when the battery gets weaker. At the moment the battery is still to good to risc damaging the Oasis by opening the case.
Here two pics of my old Paperwhite
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
1 comentario:
hey - did you get anywhere with this? the oasis battery is rubbish!!
- de
Agregar un comentario
2 Respuestas
It uses the same battery (~0.90 Wh, yeah tiny) as the earlier Oasis, so probably a good guess it uses the same process to replace the battery (spudger to pry it off slowly I believe).
Just as a FYI, the Oasis originally launched with a battery cover where the main battery was kept (~4.5 Wh), but I'm guessing they had problems with that and dropped it and so the current Oasis has this tiny little battery in it (without telling potential customers of course). The Paperwhite has a ~5.0Wh battery.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
The answers to the question are not answers, they are comments
- de
Oasis 3 uses a larger 1100ah battery. My guess is removal is the same.
Puntuación 0
Añadir tu respuesta
TheOnlyDocc estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 23
Ultimos 30 días: 155
Todo El Tiempo: 5,227
