PS4 controller is not connecting whether it is bluetooth or wired
Hello, so I was having a drifting issue and decided to fix it (used heat resistant tape and everything).
So, I put the controller back together and I try connecting to the PS4 via connector cable, it flashes white but nothing happens. I try doing it via wireless, same flashing white.
I change the connector cable, still same issue with both.
I try connecting to my PC, it says USB not recognised and it is flashing white.
I try share + ps4 button for bluetooth mode, nothing appears on my PC or phone.
I reset the controller and tried all the things above again, no difference.
I replaced the back shell and connectors with another shell, same issue.
I’m not sure what I broke at this point, when I connect it to the PS4, the colour turns orange and it is charging. My ps4 port charger is also allowing it to charge with no issue.
Es esta una buena pregunta?
