Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado en febrero de 2018. El Dell Inspiron 14-5482 cuenta con una pantalla HD de 14.0" y un procesador Intel i7.
The fan is really noisy.
The fan has been noisy in this machine for quite some time, and seems to get worse over time. When I say noisy, I don’t mean that it is running at high speeds. It just doesn’t sound right when it runs, even at low speed. It almost sounds like it has a bad bearing. I’ve opened up the machine and everything looks clean, and the fan blades look good. I’m not sure what to do. Can I replace the fan? Should I?
Es esta una buena pregunta?
Puntuación 1
1 comentario
The repair is complete! I highly recommend https://www.parts-people.com/
- de
Agregar un comentario
1 Respuesta
Solución Elegida
TYLER GOODWIN  absolutely should you go ahead and replace the fan. If it is noisey it is most likely a bearing and to keep it running like that may lead to overheating from an ineffective fan. This site will show you exactly how to replace it.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
TYLER GOODWIN estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 1,420
