What is the best processor I can put into the Toshiba L305D-S5893
I want to upgrade the cpu so I wanted to know what is the best highest preforming cpu the Toshiba satellite L305D-S5893 will work with
Es esta una buena pregunta?
I upgraded my Laptop CPU a long while back. not the same platform, but as long as the socket is the same and the FSB (for that gen it still has one I think) is rated for the same speed, then you will probably be fine.
The worst case scenario is that the cooling system can't keep the CPU cool. I found that my upgrade from celeron 1.4 to a centrino 1.73 (Oc'd to 2.4 Ghz) was not a problem. Results may vary. Still using that old thing too.
You may go with my configuration cpu as well as. Rest of the choice are left more.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 181
