Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
1.83 GHz Core Duo o 1.83, 2, o 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Why is my hard drive not recognized?
I installed a crucial MX500 SSD on my 17" iMac Core Duo computer. I created a bootable USB for macOS X Catalina. When I start up the computer holding down the option key, an image that says “Install macOS Catalina” appears and after clicking it, nothing happens. I waited all night and nothing.
Please help.
Thanks in advance.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The EMC 2104 is limited to
Pre-Installed MacOS:X 10.4.4 (8G1165)Maximum MacOS:X 10.6.8*
Go here and look up your machine and it will tell you the highest operating system your machine will take.
https://everymac.com/ultimate-mac-lookup...
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
Thanks a lot! I'll try it and let you know.
- de
@ruvelsa - Sadly the Crucial MX500 SSD won't work in your system as the systems SATA port is only SATA I (1.5 Gb/s) You'll need to use a Samsung 860 EVO SSD unlike the Crucial drive which is a fixed SATA III (6.0 Gb/s) the Samsung is auto sense so it will dial down the data rate to what the system can support in this case SATA I (1.5 Gb/s).
- de
Añadir tu respuesta
Ruben Velez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 29
Todo El Tiempo: 334
