lid was locked and I forced the lid open
My lid was locked and i forced the lid open. Now it won’t fill and I get repeated clicking noises. what would you recommend as a fix?
Es esta una buena pregunta?
@jstarr98 Sounds like you broke the locking mechanism. There is a little spring, little plastic gears, thin wiring and other little contacts and it they don’t line up just right, the washer won’t work. The clicking is the lock trying to lock but can’t. Something is broken, bent or misaligned. With the washer unplugged, you can remove the lock from underneath the lid. There are several tabs that will seperate so you can get inside the switch. Be careful when separating it, you don’t want anything to be disturb. You’ll need to know where it all goes. A new lid lock can be bought on eBay. It might be easier to just buy new.
Fue útil esta respuesta?
I replaced locking tab and lid switch and still does not work.
Ultimas 24 horas: 16
Ultimos 7 días: 72
Ultimos 30 días: 376
Todo El Tiempo: 7,682
1 comentario
I also just did this. Uggh. I think either the tip of the strike broke, or something inside the mechanism unit. Do the strikes have a magnet in them on the end, which the lid lock sensor will detect?
- de Chris D
