Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La edición más grande del décimo teléfono Galaxy insignia de Samsung, lanzado en febrero de 2019. Se envía con Android 9.0 (Pie).
Back camera glass cracked,water damage,tried repair phone no longer ch
My phone also has water damage, because the glass that goes over the 2 camera lenses on the back of the phone was cracked and some pieces completely missing from it and I dropped it in the bath tub. So I took the phone apart following the teardown on here
I have everything but the front screen taken off because I have cracks in the corner...so if I take if off it will need a complete screen replacement. Anyway I have cleaned off the corrosion, but I'm not sure how to check and see if anything is shorted out. When I try to put it back together though it doesn't turn on and it's not even registering when I plug the power cord in. When I cleaned the water out of the inside of the phone there actually wasnt even.much water in there so I'm not sure what the problem is. Any suggestiolns?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
kirstinx how did you clean it? Remember' with water damage it does not matter how long and how much, but where it shorted out.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
kirstinx sounds like you have a lot going on with your S10. Now is the time to replace the bad display assembly as well. You can not determine what works and how to clean it if you do not fully disassemble it.
The very first step I would take is to disassemble your phone. Use these guides Samsung Galaxy S10+ to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned by ultrasonic cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone (in your case replace all the previously broken/cracked parts) and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Once you got all of this done and it still does not work you can check the power on stage according to Samsung’s flowchart. If you need help with that, post some good pictures of both sides of your circuit board so we can point out the parts etc.
Imagen
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
kirstinx estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,148
