P10 Lite Replacement battery not charging
Recently I ordered a replacement battery for my Huawei P10 Lite to replace my aging and dying battery.
The part I ordered was https://eustore.ifixit.com/products/huaw...
After I had replaced the battery and turned it on, everything worked fine and the battery was supplying current to the device, but when I plugged in the charger, the battery didn’t charge. For 1 frame, you could see the battery indicator in the status bar switch to charging, after which it goes back to a non-charging state. The battery would remain supplying power to the device, but wouldn’t charge.
I know the issue is not with the device, since whenever I plugged back in te old battery, that one would still charge fine.
This has led me to believe the issue is with the replacement battery.
What I also noticed with regards to the battery, is that the model that was included in the fix kit has “SD-HW-P9PLUS” written on the flex cable to connect the battery, while this model isn’t included in the compatible devices list on the store page.
Furthermore, the flex cable has a different shape/length to the one listed in the store page and the one in my device. (See included pictures.)
What can I do to resolve this issue? Was the battery supplied in te repair kit an incompatible part for my device?
Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
