Saltar al contenido principal
El iPad Pro de 11" de segunda generación se lanzó en marzo de 2020 con los números de modelo A2228, A2068, A2230 y A2231.
Preguntas 25 Ver todo
iPad Pro 11" 2nd Gen boot loop with proximity sensor plugged in.
I replaced the digitizer on my iPad pro and it appeared all went well. I’ve done quite a few iPad’s and there were no surprises. After reassembly it went into a boot loop and at first I blamed the new digitizer. After some process of elimination I tried to turn on with out the proximity sensor and it works perfectly.
Could it simply be that I have damaged the proximity sensor cable and need to replace it?
If replaced, will the face recognition ever work again?
What other features will I not have if I don’t replace it?
Cheers
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Hi rumpig70, What came of this? Did you figure it out or end up taking it to someone? Thanks in advance!
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
hello rumpig,
the crash is related to the damage to the tape or the sensor itself (which is a triple sensor: proximity, flooding with dots and interpretation). If the sensor wasn't flooded with water when the screen was broken, chances are you broke it while removing the screen. The sensor assembly itself can be replaced, but the Face ID function will be lost. The solution is repair. If you have enough experience do it yourself. If not, send to a really good repair shop. Experience in such repairs is crucial. (Nobody who has not done dozens of such repairs before will do it well). Good luck, I keep my fingers crossed.
  • regards,
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
rumpig70 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 4
Ultimos 30 días: 26
Todo El Tiempo: 1,221
