Nvidia shield tv remote not working
I have two 2017 Nvidia shield tvs. Both remote controls stopped working. I installed new batteries in each and that did not fix the problem.
Es esta una buena pregunta?
Hi Edward,
I have the Nvidia Shield TV 1st gen.
The following is more of a workaround than a true fix. I often experience the same issue. I can eventually get the remote working if I leave it on charge for a while, then try syncing it to the Nvidia again. Sometimes I have to connect the remote to the Shield TV via a usb cable to get it to recognize the remote again. I picked up the newer version of the remote (which works much better and uses AAA batteries :-) The only thing that disappointed me about the new remote is it doesn’t have a 3.5mm headphone jack, so you can’t use it to connect your headphones. I constantly have connection problems with the old remote, and old controller, so I just use the new remote with a pair of bluetooth headphones instead. If I want to play a game, I’ll just connect one of my Xbox One controllers, which work great, except their headphone jack doesn’t work with the Nvidia Shield TV.
Hope this helps.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 907
