Help-Why does GE refrigerator ice machine and water not work
GE GFE29HSDHSS refrigerator upper ice machine is not working and water does not dispense. Lower ice maker works fine, but freezer light does not come on. Checked freezer door switch and all is good there. Lights come on in refrigerator and when door switches are depressed they go off. Everything is cooling fine as desired. Tried the lock and light button for reset, as well as unplugged fridge to try and reset. Neither worked. On display, it also doesn’t show upper ice machine as an option to turn on and off like it once did. Just seems weird that bottom makes ice and top doesn’t. All buttons work on front, including the dispense lever and light even comes on, but no ice or water. Also took out the filter and put in the bypass plug to see if that would help and it did not.
Es esta una buena pregunta?
