Use of Home button
After installing the battery, the use of the home button is now stopped. Not very happy about that. Any ideas?
Es esta una buena pregunta?
You might have torn apart the flex cable on the display for the home button when opening the phone, so i would try with a new display if the flex cable looks bad. If that doens’t fix the issue you might have damaged the home button itself when taking the phone apart. If you put a opening tool between the frame and display on the bottom left side there’s a chance that you got in contact with the home button flex cable and in return damaged the home button.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 17
