Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo M8407 / Procesador 550 o 667 MHz G4
Question mark folder strange issue
I have a G4 titanium that has a strange issue. I have a working hard drive in it. When I put it into target disk mode, I can boot other systems off the hard drive. When I try to boot the machine itself it gives a question mark folder. I have system 9 and OS X tiger installed on it. When I press alt at startup it shows only the OS X install. Clicking on it just resets the boot selector. Same thing with 10.3 and a cd. What should I do? Thank you
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Reaching back through the cobwebs to the very back room of my brain, I find a pile of papers half faded and out of sorts with no order. So as I piece the sheets back in some as-semblance of order…
I think I remember Tiger offered dual boot within its self. No true dual partition so you could run older OS-9 apps within it. Some people also did a proper dual boot setup as well, that’s when you setup the drive with two partitions completely isolating the OS and app spaces.
So the fact you see only the one startup disk is not unexpected.
As for your question mark always showing up.
This is caused when the PRAM battery has died! I hope you like the game of finding Waldo as we have a bit of a hunt to find it!
Follow this guide to get the optical drive out of your system Sustitución de la unidad de DVD del PowerBook G4 Titanium Onyx then pick up from Step 6 from this guide Sustitución de la batería PRAM del PowerBook G4 Titanium DVI. Lift the battery board fully out so you can get to the battery.
Imagen de PowerBook G4 Titanium Onyx Unidad de DVD
Guía
Dificultad:
Moderado
Imagen de PowerBook G4 Titanium DVI batería PRAM
Guía
Dificultad:
Moderado
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
I would never have thought to replace the replace the battery, Apple computers don’t make much sense! Thank you I will open it once more and replace the battery see how it goes. Thank you
- de
@idintfixit - Don't forget to score & accept the answer if you're set!
- de
its the next day, got a new battery and it actually worked! crazy! thank you!
- de
Añadir tu respuesta
Mihai Paun estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 33
Todo El Tiempo: 576
