Saltar al contenido principal
Fecha de lanzamiento: 24 de enero de 2008; 8 MP, zoom óptico de 3x, sistema de estabilización de imagen óptica integrado y software de detección de rostros; Procesador de imagen DIGIC III.
Preguntas 13 Ver todo
How do I reassemble the lens unit itself?
The lens stuck in the open position during our vacation. No amount of jiggling, banging, cursing, swearing, or praying would fix it.
Upon returning home, I discovered this web page and through its amazing instructions (Thanks, everyone!) I had no trouble removing the lens unit.
Now, travelling in uncharted territory, I started dismantling the lens unit itself. Not difficult; just the four screws that go into the back of the black plastic casing, one lock tab, and it almost falls apart.
I found traces of beach sand, left over from a previous vacation, so I cleaned everything thoroughly.
Now the hard part. The unit basically consists of several concentric sleeves that have cam grooves in them. Each sleeve will assemble in any one of 3 possible alignments, but obviously only one is correct. Does anyone know the correct alignments?
I would attach pictures, but I don't have a camera....
Thanks.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Bill, download the service manual from here and check chapter 2.12. I think that shows you how to disassemble the optical unit. Lots of little fun parts :-) anyhow, good luck and let us know if this works for you.
Fue útil esta respuesta?
Puntuación 4
11 comentarios:
Hi!
Thanks for the very fast response! I have downloaded the files and taken a quick look at them. Looking good! I'l have more time this evening to get back into the project in detail.
Thanks!
- de
You are very welcome and thank you for accepting my answer.
- de
I am in the middle of taking the lens apart of my canon sd 1200is can I get a download of the chapter?
- de
Richard, give it a try. The service manual is complete, not broken down by chapter, and it is for the SD1100, so there may be some differences.. :-) good luck http://www.keepandshare.com/doc/3161724/...
- de
The manuals only seem to go down as far as removing the lens unit and for dissasembling/reassembling the protective shutter blades. In order to free up mine I had to dismantle the lens unit itself, and couldn't get it back together until I found the perfect solution a few days ago: I redeemed frequent flier miles and acquired a newer, better model of the camera and gave up on the dismantled one <g>.
- de
Mostrar 6 comentarios más
Añadir tu respuesta
Bill estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,289
