Down on D-Pad not working
I have an Xbox one S controller that's not heavily used or beat up, as a while back, less than a year after I had gotten it (when GameStop had a good trade in program for the original model to get the S model), down on the D-pad is continuously registered despite my best efforts, and despite the buttons clicking and feeling like it's new. Microsoft refused to warranty it, so I ended up getting another one and sitting on it for a while, though I would like to fix it if I can.
So far, what I've done (after some intense Google searching) is taken the whole controller apart carefully and cleaned the board around the D-pad with 91% rubbing alcohol, and I removed that little sticker with the D-pad domes underneath it and cleaned both the board underneath that and the sticker as it seemed some dirt had gotten to it, but still no dice.
I plugged in the controller whilst open without the sticker with the domes on the board to see if that would make a difference, and it’s still registering down. After that, I used a DMM to test continuity between the outer and inner black ring contacts for that particular button, and there's no continuity so it doesn't seem like it's a simple short making it think the button is continuously pressed. I tried following the traces back to see if I could find something obviously wrong, like a bad resistor or something, but without anything to reference, I didn't get terribly far. SW12 is the down button. I also checked continuity to make sure there weren't any broken traces away from that bottom button. Those were fine too.
It's not the end of the world if I can't get this controller to work since I could probably get a new bottom board if need be, but if anyone here can help me get any closer to making it work, I'd be greatly appreciative.
Es esta una buena pregunta?
Looking at the picture D12 seems a little "sad" (bottom left of the board, next to the marker line), it's connected to the down d pad. I'd say have a look at that
- de Roman Prochazka
Here's how to test it: take your multimeter and have it in continuity mode. Place each tip at different end of D12. If you hear a beep D12 could be faulty. You should only hear beep when down on your dad is pressed
There's no continuity on D12. As a matter of fact, after probing some more, I found out that one side of D12 is the pad, the other is ground, so D12 is working fine and there's no short to ground that I can see.
- de Justin Biot
