Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guía de reparación e información para los controles Joy-Con de Nintendo Switch
Joy Con still drifts just after replacement
I had a really bad up/left drift problem on my left joycon, so I ordered the repair kit and followed the guide. After replacing the stick it now has a slight downward drift problem, noticeable in calibration and while playing a game (tested game was Animal Crossing New Horizons, the character would slowly move downward when the stick was not being touched)
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 10
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Make sure the ribbon cable and the connector for the joystick is clean. Contaminants there can sometimes cause drift
Fue útil esta respuesta?
Puntuación 2
Did you try updating controllers? It worked for me
Puntuación 2
As well as the 2 answers above you can also try re calibarating the joy con and lastly reset the console by holding down the power button for 10-12 seconds. Usually the 4 things mentioned here combined will sort it out. Changed about 5 sets so far and no issues now
EDIT Sorry didn’t fully read your question seems you did calibarate it already. So it could be the housing around the joystick has become dislodged. You cant also rule out that the replacement stick is just faulty. Usually in those kits you get 2 or 3 sticks so try another.
Puntuación 2
Añadir tu respuesta
Falling Rose estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 97
Todo El Tiempo: 7,739
