Saltar al contenido principal
El Dell Latitude E6400 fue el portátil corporativo de 14.1" convencional de Dell presentado en agosto de 2008.
Preguntas 20 Ver todo
Screw size or where can I get screws?
I recently acquired a Dell Latitude E6400, I dropped an SSD into it, changed the keyboard and Installed windows 10 on it. It is working like a champ, ofcourse I won’t be doing any gaming or major editing on it.
The issue is that the SSD connectors are a little looser than the old HDD connectors, hence the SSD easily slips out or doesn’t maintain connection. The original screws that would hold the HDD in place where not with the laptop which is why I need to know what screw size or where I can get the screws to hold the SSD in place correctly.
I’d also like the screw for the DVD player also if possible. After my long description, let me boil it down.
I need the screw size or where I can get the screws for my Dell Latitude E6400, that hold:
  • the SSD
  • the DVD tray
in place. They are the screws that are used once the bottom cover is in place. Please see image provided.
Thank you in advance
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
I found the answer to the SSD screws, it is m3 x 3mm screws. However I'd still like to get the answer to the security screw for the DVD drive.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
latitude-e6400_service-manual_.pdf
hdd… see pg 51 for start…read on
dvd… see pg 71 for start… read on
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Alx V estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 8
Todo El Tiempo: 332
