Swapping logicboards and compatibility between mid 2015 and late 2015?
I have a 27” Imac mid 2015 and I want to swap its logic board with one from the late 2015 iMac.
Are these logic boards compatible?
Will the late 2015 logic board fit the case of mid 2015? Its conectors are in the same place of the mid 2015 logic board?
Will all of the mid 2015 logic board components (processors, GPU, SSD, etc..) will fit and work properly in the late 2015 logic board?
Also is the mid 2015 power supply the same as the late 2015?
Es esta una buena pregunta?
2 comentarios
What is your reason in swapping out the logic boards?
The systems firmware (EFI) won't support the others CPU's.
● iMac15,1 - Haswell CPU’s
● iMac17,1 - Skylake CPU’s
- de Dan
Hi Dan, because I have upgraded the imac and SSD is slow speed because mid 2015 has PCIe x2 only. Late 2015 has PCIe X4 so speeds would be much better and higher.
Swapping logicboards with all componentes would affect the campatibility? I mean I would remove the mid 2015 logicboard and its components and swap it with a late 2015 logic board with its components.
From the images above the bolts seem in the right place to fit in the mid2015 case and the connectors are in the same place to be plugged. The only visible difference is the wifi card that is slightly placed in the right near the right speaker but that would fit as well i suppose.
- de papaformigas
