Blacklit LCD but no image/black after battery replacement
After replacing the battery on my iPad Air 2, the screen does not generate an image when it’s turned on. It is black, but backlit with a whitish horizontal bar that changes from a few pixels in width to an inch and also appears/disappears as it boots up/off. Everything else works include the backlight, power off/on, siri, sound, wifi, volume, etc. It’s unclear if the touchscreen works as I’m not sure how to check this.
Below are some things I’ve done:
- Every reset imaginable (holding power/home button with variations of it to restart the ipad)
- Disconnected and reconnected the battery
- I’ve inspected the ribbons and there is no damage
- I’ve reconnected the ribbons several times and everything seems to click in
My current theory is I need to replace the logic board as I may have damaged it when lifting the panel up. I’m not sure how to check something like this. I do not think there is any damage to the LCD.
Any help is appreciated!
Es esta una buena pregunta?
