Logitech 510 Mouse does not transmit to computer.
The mouse does not transmit to the computer and the “invisable optic” light does not light up.
Es esta una buena pregunta?
Try a new battery and check the connections on the battery and make sure the battery is facing the correct direction.
Fue útil esta respuesta?
I tried that--problem is that the LED on the bottom does not light up, and I disassembled the mouse, inspected it, and can not find any obvious issues.
Thanks
Anything else you can suggest?
My guess is you need a new mouse. If none of that fixes it.
One could try re-pairing to the dongle through the Logitech Unifying Software.
And the “invisible” optic should be indeed invisible.
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 338
