No boot no dfu stuck on 0,16A
Hi guys, need help... iPhone XS Max no Startup, no Apple Logo, no Dfu Mode, after pressing power button stuck on 0,16A After 20seconds restart itself and stuck again 0,16a
Es esta una buena pregunta?
I’m wondering if there’s a short somewhere. I had an X in recently where it would draw .44a then drop to .01a and cycle back and forth every few seconds. Maybe send it off to iPad Rehab or STS Telecom?
Fue útil esta respuesta?
Thanks vor answer, but I wannt to fix it myself
If you want to repair it yourself do you have access schematics? Try getting an account to zxy it's 64 dollars a year. You will need a multi meter, a microscope, most likely a hot air machine, a soldering iron, you will also need the higher to split and reattach the board (it's a split board and has contacts around the outside of the board). I would recommend buy some iCloud locked phones to practice on and watch a lot of videos on YouTube from jessa at ipad rehab ipadrehab.com and Jason at sts telecom ststelecom.com I hope this information helps. I would look at what it takes to repair a board on iPhone x,xs, xs max,xr they basically use the same board you will get the idea what it takes to do it.
I do iPhone repair about 5years and sure I have enough experience with logic board repair, just here is something special and I can’t found fail… I’ll try first reball Power Management Chip if still same problem than I’ll reball CPU
Ok, I didn't know your experience. Sorry it sounded like you were new at this. Hope you can figure it out.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 184
