Saltar al contenido principal
El primer modelo de iPhone, modelo A1203 con 4, 8 o 16 GB de capacidad y una parte posterior de aluminio. La reparación requiere una cantidad significativa de destreza, y puede requerir un poco de soldadura.
Preguntas 221 Ver todo
How to tell if battery is dead
I am trying to fix my 1st gen iPhone that I just bought as non working. It seems that the battery is bad, but I want to make sure that it's really the problem before ordering one. Whenever I tried to restore it in itunes or 3utools, it always tried to reboot and just turned the screen off every time. Sometimes, the backlight would turn off and a ghost of the screen could be seen for a few seconds. I can get the phone in DFU and recovery mode no problem, but as soon as I unplug it, it shuts off immediately. With the latest itunes I would get error 1604 and 1603. Is this likely the battery or is the dock connector or motherboard bad? I tried to download older itunes versions, but even on vista or Windows 7 machines I had no luck showing the “iphone software update server could not be contacted”.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Does it work O.K. with the power supply/charger plugged in?
If yes then replace the battery:
iPhone 1st Generation Battery Replacement
If not them you have a more serious problem, I would imagine.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
The phone can get it DFU and recovery mode, but I can't boot up the phone or properly restore it, should I try changing the battery or is it a lost cause?
- de
Itunes is not longer supported by Apple, maybe that is why you got that error. Now Apple application is named Music App.
Puntuación 0
Añadir tu respuesta
David Gagnon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 68
